Clearing a mint (9/10) condition Futaba 3PKS 2.4Ghz FaSST set.
Complete with R603FS receiver, manuals and box.
Still one of the better sets in the market.
FEATURES: Designed for the top-level racer with driver-friendly features such
as multi-position wheel, multiple menus, Direct Select for quick
access, failsafe, jog switch key panel and much more.
* Advanced Braking System (ABS)
* Throttle Acceleration, Pre-Set and Auto-Start
* 20 model memory
* 10 character model naming
* Large scale car functions and boat mixing functions
In addition to great performance in R/C car and truck applications,
this system is also ideally suited to the rigors of boat racing
* FASST (Futaba Advanced Spread Spectrum Technology) sends twice as much information to the receiver at eight times the resolution of
standard systems for unsurpassed control and smooth servo travel
"Auto Detect" instantly determines whether HRS or PPM mode is active
in the transmitter
Special ID code prevents signal interruption by rejecting unwanted
signals
Can be converted for left hand use
SPECS: Transmitter;
Current Drain: 250mA or less
Transmitting Antenna: 2.4GHz
R603FS Receiver (FUTL7630)
Reception Antenna: Diversity type (internal and external)
Power Requirement: 6V NiCd battery
DSC Function Available
Size: 1.5 x 1 x .55" (39 x 26 x 14mm)
Weight .50oz (14.1g)
Looking at $230 (firm).
Pls sms/whatsapp 93382461 if interested.
Thanks.
* 20 model memory
in the transmitter
signals
SPECS: Transmitter;
Thanks.
