Brought 200 used once.
Selling at 180. still very very new.
Specification
Operating input voltage DC 11~18 V
AC 100~240V 50/60Hz
Idling current approx. 100mA
Charge/discharge power max. 90 / 5W at DC input
max. 50 / 5W at AC input
NiCd/MH 1 to 15 cells
LiIo/LiPo/LiFe 1 to 6 S
Pb 2 to 22 V
Charge current 0.1 to 6.0A
Discharge current 0.1 to 1.0A
No. of cycles up to 10 times, N/A for Lixx
Battery data memories up to 10 data per program
Battery capacity range 100 ~ 65000mAh
Delta-peak sensitivity Disable, Delicate, 5 ~ 20mV adjustable
Trickle charge current off, 50 ~ 300mA adjustable
Current drain in balancer 200mA / cell
Weight 670 g
Dimension 140 x 140 x 45 mm
User's setting-up parameters
Lithium battery type LiIo:3.6V, LiPo:3.7V, LiFe:3.3V
Lithium battery charge mode Normal, Balance, Storage, Fast
NiCd/NiMH charge mode Normal, Linear, Reflex
NiCd Delta-peak voltage sensitivity disable, delicate, 5 to 20mV adjustable
NiMH Delta-peak voltage sensitivity disable, delicate, 5 to 20mV adjustable
Pb battery charge mode Linear, Pulse
Battery temperature cut-off Off, 20 to 80C
Waste time between charge/discharge cycle zero to 60 minutes.
Trickle charge mode Off, 50 ~ 300mA adjustable
Integral timer limit for safety Off, 10 to 1380 minutes
Maximum charging capacity limit for safety 50 ~ 120%
Key beep and buzzer sound ON/OFF, melody selectable
Input power low alert 10 to 11V
LCD back-light brightness Off, 1 ~ 8
Specification
AC 100~240V 50/60Hz
Pb 2 to 22 V
Weight 670 g
