Selling under utilized bike for $950.
Used in East Coast Park track for less than 5 times only.
Strida 5.0 Technical Specs:
Bike weight: 19.4 lbs (8.8 kg)
Frame: 7000 series, powder coated, rustproof aluminium
Drive train: kevlar greaseless belt drive (good up to 50k mi.)
Wheels: alloy 16" (41 cm)
Tires: Black skin walls with reflective scotchlite stripe
Brakes: cable disc brakes
Speeds: single speed (56 gear inches)
Folded size: 45" x 20" x 9" (114cm x 51cm x 23cm)
Grips: gel
Bottom Bracket: welded
Luggage rack: holds 30 lbs (14kg)
Rider specifications:
Weight limit: 250 lbs (110 kg)
Height limit: 5'4" to 6'4" (163 to 193cm)
Grips: gel
