Only use a few time so practically like new. Selling $80 for the E-logger plus additional LCD power Panel Display
SMS/Call 92723423 if interested.
EagleTree MicroPower E-Logger
NEW: Eagle Tree continues to innovate in data collection with the eLogger V4. In addition to greatly enhanced resolution and accuracy, the V4 now supports voltage to 80 volts, current to 100 amps (150 amps optional), GPS (with optional GPS Expander), 5x the logging capacity of the V2, Three Temperatures, and Throttle Logging (or logging of two RPMs)!
FEATURES |
Accepts optional inexpensive sensors for GPS, temperature, RPM
(brushless, magnetic or optical) airspeed, altitude, servo current
and more
Logs throttle movement with optional Y-cable
Four times the memory capability of the V2
Current measured with a true Hall Effects sensor-not a resistance
shunt that creates heat and robs power from the system
Fully compatible with Windows Vista, 98SE, ME, Win2K and XP
USB live mode support displays info from the model live on the bench
on modeler's PC
All data is logged to permanent memory, which retains data even when
power is removed, adjustable logging rate (1-10 samples/second)
and lossless data compression for long log times
State of the art Windows virtual playback display and graphing
