hello,
im busy here preparing a hk500gt that i could take over second hand.
now im looking into my throttle curves and the settings i should use.
with a calculator i come to a head speed of around 2350 rpm @ 4.2/cell and 2000@3.7/cell
the only guideline i could find is in the original trex 500 fly bar heli, and they are talking in the range of 2900rpm
data as far i can find on my heli,
1300kv motor
13 tooth pinion
162 tooth mean gear
using a 60A esc
6S 3000mah lipo
i won't be using it for any planned 3d action, only hoovering and field circuits for now.
so i won't go extreme on the pitch settings as well, -3 to + 7
so will the headspeed do at a 100% throttle curve?
i like to fly in idle up. i tried flying both in idle up and with a 0-100% throttle curve. with a small mcpx that i use to play with different settings in my remote. but i find the idle up the most pleasant to fly.
thanks in advance
erik
1300kv motor
13 tooth pinion
162 tooth mean gear
using a 60A esc
6S 3000mah lipo
thanks in advance
erik
