Hi all gurus
need help in this matter. i'm looking to scratch build. my skysurfer is getting a little boring and i'm looking to scratch build a foamy.
anyways, i intend to get these few items. would the battery and motor and esc match well?
HK2836 EDF Outrunner 3800kv for 64mm
Specs:
Kv- 3800
Dimensions: 75 x 28mm
Shaft diameter: 3.0mm
Shaft length: 10mm
Voltage: 14.8V
Weight: 97g
Output Power: 520w
Max current(<60s): 35A
RPM/V: 3800
Thrust: 1100g(38.8oz.)
Recommended model weight: 600-800g
Recommended model fans: 64mm Fans
Mounting Hole Bolt Circle: 18mm
Mtg. Hole Number & Size: 4 x M2
ZIPPY Compact 2200mAh 4S 25C Lipo Pack
Spec.
Capacity: 2200mAh
Voltage: 4S1P / 4 Cell / 14.8V
Discharge: 25C Constant / 35C Burst
Weight: 210g (including wire, plug & case)
Dimensions: 107x28x34mm
Balance Plug: JST-XH
Discharge Plug: XT60
HobbyKing Red Brick 50A ESC
Specs.
Max Amps: 50A
Ubec: 5v / 3A
Cells: 2~3s Lipoly
Size: 47mm x 9mm x 33mm
Weight: 29g (Inc Wires)
Specs:
Kv- 3800
Shaft length: 10mm
Voltage: 14.8V
Weight: 97g
Output Power: 520w
RPM/V: 3800
Spec.
Capacity: 2200mAh
Specs.
Max Amps: 50A
Ubec: 5v / 3A
Cells: 2~3s Lipoly
