Got this off ebay and thought I share it with you.
The Bit 561 is the one on the left.
It is a spiral cutter.
Shank is 1/8".
Test cutting a piece of 5mm PVC sheet.
Fit it in a Dremel...
Go for high speed....
Just poke thru the PVC sheet and drag the bit in any direction..
The cutting is very fast.
In my hand, I can only do damage.
If used properly, it is wonderful tool.
Understand that it can also cut acrylic quite cleanly.
Planning to install the Dremel under a workbench with the Bit sticking up.
Install a guide fence and I have a "Table Saw". <br> <br>
Shank is 1/8".
