Hi, anyone knows where to get bearings for brushless motor as well as metal shafts? Thinking of DIYing my own motor shaft as I foresee more bent shafts in the future. Thank you!
Motor bearing and shaft
Most motor has its bearing glued to the casing..thus, difficult to take out the bearing.
If yours can take out, then just get any bearing with the same size (outer diameter and thickness).
As for motor shaft, check out those heli's main shaft or tail shaft. If the diameter is the one u want and the length as well, then use it.
I replace a few motor using heli shaft before and it works well.
