Hey guys,
Just wondering if anyone experienced this before. This situation happened to my OrangeRX R610 RX and again to an OrangeRX TX module.
First, I was using my OrangeRX R610 RX as per normal, it had been working fine all along. One fine day, when I connected the batteries and wanted to go flying, there was no red light on my RX. From that day onwards, it ceased to function. It was akin to sudden death. I can do soldering, and I figured that if it's just a bloated capacitor I could simply swap it out. Upon inspection of the board, there was nothing, no burnt marks, no bloated caps, everything just looked normal. Could it be one of the electronics that wore out? Is there anyway to save it? Beats me why something would just die like that. It probably is just a single faulty component that can be replaced.
Secondly, same thing happened to my friend's OrangeRX TX module. He had been using it fine all along in his Turnigy 9X, he didn't drop it, nothing. One day when he powered the TX on, the Orange just didn't give that initialising beep. Pressing the bind button elicited no response at all. I dismantled the casing and again, found no abnormalities. Nothing burnt. What's going on? Are Orange products known to fail like that?
I've heard that some manufacturers set an expiry date on their products. Meaning that after a certain time, that critical component would be programmed to die/stop working. This is especially easy to do with the ATMega chips (or any other MCUs for that matter) that are found in Orange devices, let's say, with every power cycle, add one to a counter and write it to EEPROM, then once that counter reaches a certain value, just stop the MCU from working by running a separate set of code that is non functional, and tadaa! It's such a simple piece of code, even I could write it. You would be sure to continually have to buy Orange products, and your hard earned $$$ goes into their pockets.
I might try FrSky if Orange products are trash.
