hi,guys,i have a T580 quad,been flying in ang mo kio,just wondering if there are anyone else in the vicnity? any other flyer is welcomed too
any Quad flyer in ang mo kio?
Hi,The t580 is relatively easy to fly due to the auto leveling capabilty,for the direction orientation,you might take a while to get used to.(You can make your own marking on the landking skid for the front).The altitude hold is +/- a metre,(for my craft),and it will go into attitude hold when there is no throttle input for 2 seconds.Just in case,if you lose orientation and there is a risk of crashing,you can try throttling up and get the craft higher up to the sky and the auto leveling and altitude hold should stabilized it pretty decently and from there,you can regain control.
Maybe you might want to get a few more props,although there's already 2 props included.One thing to take note,don't screw the nut on top of the prop too tight,it will crack the props(happen to me).Alternatives is to use Loctite or a nylon lock nut.Otherwise,it's quite a fun machine to fly,always check for the temperature under the housing where all the esc and control board is situated in,if the temp gets too high in it,(maybe you are flying on a sunny day and due to the black cover,the temp might get a little high inside),it's not good for the electronics.But it's just a simple thing to take note of,if not add a few strips of led and fly at night! hahaha
Hope my personal experiences helps Maybe we can fly together if you decide to get one,its quite fun.Cheers!
QuadCopter builder
Originally posted by Rude View Posthi,guys,i have a T580 quad,been flying in ang mo kio,just wondering if there are anyone else in the vicnity? any other flyer is welcomed too
With Gaui 500x & have 8 set carbon firber custom build 350 QuadCopter
Also direct importer the New Version Walkara UFO#5.
My Contact 84489917.
email. amasleong@gmail.com
Hi Rude, i flying for test, at Buangkok Crescent the big field...Haha...i just back to this Hobby 15 year ago on Heli Gas...Mode1... Now In Custom QuadCopter 350 leaning at Mode2. Yes alone alone
also have Gaui500X.
More time Build for my Friend..I work at home Base....Are you flying T580 Hah? You Good in Flying.. we Fly togetter, i am very very free.
Hay check my link:
