Request to help build E-ginger for soaringcomposite for his client.
Haha macham professional..
Started off with a little sanding between the flaps and ailerons, a little rough but no big deal. On closer examination, there is no marking on where the flap link post is going to be (top driven). Trial fit the servos to determine where to cut the slot for the flap link.
I taped the servo with some masking tape for future removal and glue it down with silicon glue and added some 3/16 balsa block with CA to secure it. Did the same for all the wings servos.
Once the flap link slots have been cut and the link post epoxy harden, fitted the linkage. Oh yes, neutral all the servos before gluing into the wings.
Ran out of spares so had to shelf the wings for now..
Started next on the fuselage. Had to dermel the wing seat opening to fit the 2 servos directly under the wings. For non-powered ginger, you can place the servos inside the canopy, lots of space. This space is now reserved for motor, lipo, esc and rx.
Cut some carbon sheets to fit both servos and slide it into place. Check that you don't place the servos direct under the wing wiring outlet. You don't want the wires to touch the elevator and rudder servos.
Next I made a rudder conduit support to hold the rudder conduit in place.
If you look at the above photo, you can see a black disc. That's the motor mounting plate. I had couple of carbon cloth added to increase the thickness of the original FG mount. I find it a little too thin.
That's my 1 day build. Stay tune for more work tonight.
