Hi. Thought I post this new AA ( Xtwin ) powered plane that I came up with recently. If you still have your old Silverlit Xtwin ( twin motors ) plane, get the gears out and you can try to make one too
I guess you can try substituting the depron and EPP materials ( materials are from US ) with balsa (for fuselage) or local foam sheets (3mm? ) from artfriend ?
Just hope to share the fun which I had with this plane with all of you here
. Cheers !!
Short vid here : http://www.youtube.com/watch?v=WH0DYwZdP4w
and the plans & some photos :
. I guess you can try substituting the depron and EPP materials ( materials are from US ) with balsa (for fuselage) or local foam sheets (3mm? ) from artfriend ?
. Cheers !!Short vid here : http://www.youtube.com/watch?v=WH0DYwZdP4w
. Am very glad it flies. Now awaiting someone else to make one too and see if the plan posted needs revision.
. But having burnt myself once with the RFFS100 system (from DWE which went bust) I learnt to take it easy. So just play with the cheaper Xtwin gears.
