Mid airs are common at the slope, they are often unintensional. My ginger was unfortunately damaged during one of the test flights at sedili.
This was how i went about repairing.
Damage to top of wing. a long crack.
Bottom is worse. some cracks and one large portion of the wing skin was gone
hollow molded so how to repair?
For the top wing skin, i chose to fiberglass from inside.
Soak up excess epoxy as they serve no purpose and adds weight
Use x-acto knife to clean up the damage perimeter. Prepare a block of foam ready
Measure and cut a piece of foam that fits the shape of the damaged area.
Leave a gap in the LE. This is for strengthening the LE later. Then use 3M77 to glue in the foam.
Use pen knife carefully cut away excess foam. Not too much.
Sand to airfoil shape
Looking good
Prepare FG cloth. i use medium grade
Fill up leading edge with epoxy micro ballon mix. This will strengthen the LE.
I lay 2 layers of FG cloth. use satay stick to ensure smooth surface
Again soak up all the excess epoxy
Leave to dry overnight. Then remove excess FG cloth. And start sanding! i use 200grit with water. then finish with 600 grit sanding paper
Almost there. keep sanding
Airfoil maintained and finished repaired area is very strong.
Masked out for spraying
Close enough.
From far, cant see the difference
To my surprise , I weighted the finish repaired wing it didnt have any weight increase compared to before. Foam and FG cloth are light, important point is rem to soak up the excess epoxy.
Hope this helps for those who needs to repair composite wings next time.
Looking good
Close enough.
