WTS - Multiplex Cockpit SX @ $188
Comes with
- Stock antenna, can be slotted out of sight into TX
- Ni-Mh battery
- 1 x Mulitplex standard servo
- Box & Manual
- Charging cable soldered with dean connector
- Blue metal TX stand
- Channel Check Plus Module. With it you'll never clash your frequency with other flyers! You can also scan all the frequency available to see which is in use!
On 40Mhz & 41Mhz synth module with stock antenna(No TX crystals required )
This is the REVIEW on the transmitter.
These are all the information tutorials you need.
Self collection in Punggol.
Comes with
- Ni-Mh battery
- Box & Manual
