can this
35A Brushless ESC (Car)
Product Code : [K10212TA]
Feature:
-Reverse and ABS brakes are options,support 1/2 or 1/3 neutral mode radio system.
-Small and compact PCB design for ease of installation.
-Large heatsink for great thermal performance.
-High compatibility to work with 98% brushless motors in the market.
-Ultra smooth motor start design to run with all kinds of brushless motors.
-The power inlet adapts Japanese made "Low ESR" capacitor in order to provide stable power source.
-T BEC power outlet adapts a Japanese made specialty polymer aluminum electrolytic capacitor. It porvides better noise filtering capability than other BL ESC in the market, and moreover to give more stable performance of R/C receiver and BEC.
-The BEC adapts dual TO-252 package regulators. It provides great thermal performance with 2A peak current.
-The throttle has more than 200 steps resolution that provides great controlling sense.
Specification
-Continuous current:35Amps with porper air flow
-Surge current:45Amps for 15seconds
-Supporting motor types:2 poles to 10+poles in/outrunner brushless motors
-Supporting maximum RPM:2poles=>190,000rpm
-Supporting input voltage:5.5V~16.8V
-Supporting battery types: Li-ion/ Li-poly 2~4 cells, Ni-Mh 6-12 cells
-BEC output: Max current 2A
2 cells Lithium/6~7 Ni-Mh cells=>4servos
3 cells Lithium/8~9 Ni-Mh cells=>3servos
4 cells Lithium/10~12 Ni-Mh cells=>2servos
-Size:45X22X12m/m
-Weight:25g
Accessories
plus
-ALIGN standard 3mm gilt terminal X3set(Max. current 35A)
+ this
Excellence Brushless Motor / Motor / Motor Accessories
130 Brushless Motor 6200KV
Product Code : [EX1175]
Specification
Shaft size
ia. 2.0mm X 10mm
Dimensions
ia. 20mm X 30mm
Weight:50g
Rpm/v(Kv): 6200KV
Idlecurrent(IO): 1.6
Resistance: 0.0492
Max Amps(A): 15
can use to upgrade in TT ZK2,mini-t, or half8????
Feature:
Specification
-Size:45X22X12m/m
-Weight:25g
Accessories
plus
+ this
Specification
Shaft size
Dimensions
Weight:50g
Rpm/v(Kv): 6200KV
Resistance: 0.0492
Max Amps(A): 15
