Once the carbon fiber tubes have been glued in place (araldite mixed with micro-balloons to reduce the weight) the wing minus cables will be laid on a un-cut piece of Depron and pressed hard down on same. This will make lines where the carbon tubes have to go so that I can route grooves here as well. There is no need to apply this technique to the cables as they fit snug in the grooves. Once routed 3M77 spray and bingo we have the wing ready for trimming to match the original.
Now I have to see when the MOHA is going out to play Mahjong so I get back into sanding to get a wing profile
Lovely Shape isn't it?
. So I have pressed on and fitted the engine pods to the wing. The vertical mount for the AXI's came really handy as it was possible to use a square to get the sides at right angles to the mount.
You can see in the attached picture the Lite ply motor mount an odd shape but it allows the air to pass through. You will also note that balsa alignment bar inside the pod is now hollowed out. So how did I get it square...? very simple if you look closely you will see a Lite ply plate between the balsa post and the engine mount on the side of the engine pod. There are four of these one on each side of the engine pod, needless to say they ae most critical parts as they have to be identical in length
Yes the first trial fit of the three assemblies, OK AstroBoy you can collect your Mutley medals now......
