After a long delay due to reams of work at the office and having to go outstation the Concorde is back on the bench. The underbelly of the wing is complex, loads of curves and angles so one awful lot of sanding to get things correct. As the meshing of the belly pan to the fuselage will be difficult to achieve once the wing is in place two strips of 5mm Depron were taped to the underbelly to get a sort of mini wing to get the shaping correct. One more final sand with 400 and 600 grit and then we can put the fuselage aside and get into that big delta.
As I advised in another thread I now have Reflex XTR version of the model so I have been test flying the model at the field to see how it behaves with two 6 x 4 propellers. Speed wise similar to the F-15 of AstroBoy's no real nasty tendances except a marked pitch up from low throttle to hitting the firewall, as expected it will fly slow at very high alpha's looks very impressive to say the least.
Here is a picture of the underbelly located in the fuselage.
So total AUW with flight battery is still about 500 ~550 grammes, i think, again!
) this scheme had a red top to the fin which I like, you can see the missile
I Love It!
on it so to speak. One observation that I have made is that a high alpha of say 20 degrees the drag kills the speed dramatically, nose down and you are back in business. It also seems sensistive on the elevator anymore than 18 degrees and boy you are in for the stall of your life complete with spins, thanks goodness it is a simulator there are more Concorde darts sticking out of the ground of Edgfield plaines than there were Concordes ever made. Still I am sure the obvious is staring me in the face as they say
, I have yet again deviated from the original plans as I was concerned of wing flexing especially the leading edges of the delta. So I am using MidWest 0.188" fiber tube as stiffeners and also for the original main spar, there is also the need for the grooves for the servo wires / extension leads and of course the power leads to the ESC's.
, "been there done it" a perfect slot not with Concorde wing..
