Where can order this clone...
I had to use one inner hole instead. Even with this, I had to reduce my swash pitch mixing down from 60% to about 50% to achieve +-11 degrees of pitch.
The heli seems slightly tail heavy probably due to the weight of DS520 servo. I might use a smaller rudder servo later to achieve better CG.
) with this current setup to confirm that the tail really holds before changing / upgrading any electronics.
...One of my all time favourite heli is a modified Picco-Z
) I like the use of the Torx screws on this clone instead of the 0.9mm hex screws. The torx screws are more 'forgiving', easier to screw on and don't stripped easily.
