The Watt's Up watt meter is already a very useful tool to have around to check the amps drawn in a motor setup, the overall voltage of the battery and so on.
I was thinking that I may have to get myself a separate voltmeter to check the voltage of individual lipo cells cos the watt meter only had deans connectors. But instead, I rummaged through my toolbox and found a female dean connector and those "needles" that you find with the voltmeter. So I started cracking. I'll use the "needles" to check voltages of battery packs with non-deans connectors.
My set up:
1. Soldering Iron
2. Soldering Flux
3. "Needles" (if someone has the correct name for it please fill in, thanks
4. Heat shrink tubing
5. Clamp
6. Watt's Up Watt Meter (or any other brands of the same sort)
My set up:
1. Soldering Iron
2. Soldering Flux
5. Clamp
.... Just manage to confirm they called it Test Leads
