Got a rjx head from a brother here...trying to fit it onto a raptor.
Main shaft works out fine and after a night of effort, I have got the head on the heli. Ran into a few minor problems. Need some advice.
1. Ball links
Are the ball links on the rjx a hair smaller than raptor's? The very very short linkage that connects the mixer arm on the blade grip to the flybar carrier is non-adjustable?
2. Paddles
Generally what paddles are preferred? I am using the Align 4mm CF paddles off my 700N now. Looks a little too big and am afraid it might "over power" the blades. Got some plastic paddles to recommend? Prefer snappy(but not overly) paddles that tracks well in ff. Raptor 4mm plastic paddles ok?
3. What holes on the mixer arm?
From what I have done and measured, using the most responsive setting for all holes, I get +/15collective and 9++degree of cyclic...probably due to a slightly smaller swash on the raptor. Moved the balls on the head to give +/-13 collective and +/-8 cyclic. Initially I wanted to use the most responsive settings and just adjust the servo throw(since mechanical mix always have more resolution, so epa not really that critical compared to eccpm).
However, the rjx manual states that using the most responsive hole can strip plastic gear servos...and that is on a eccpm machine where load is divided be 3 on to each servo...my question is what are the chances of me stripping the servos on my raptor with the most reponsive setting for every hole?
4. The jesus bolt.
How tight is this suppose to be? It clamps the head onto the main shaft to prevent wobbling, which means its got be be real tight? But yet I thought such high risk critical bolts should not be over tighten to prevent failure. How tight should it be?
1. Ball links
2. Paddles
4. The jesus bolt.
