High quality balsa 3D plane. Check it out on youtube or vimeo for its videos. The plane comes with APC 13x6.5 prop, Spinner, Thrust 30 brushless motor, HS 5065MG for elevator and pull-pull rudder, HS 65HB for ailerons. Doesnt come with ESC, rx and batteries. Recommended batteries are 3s 2200mAh. Never crash before and condition at least 9/10. Price $450 negotiable. Deal at Serangoon Garden McDonalds. PM me or reply to this thread if u are interested. feel free to ask any questions too!
WTS Precision Aerobatics Extra 260 (yellow)
here are some photos to show the condition...
1. elevator push rod with digital metal gear hitec servo. pull pull rudder installations. hinges are sealed.
2. pull pull rudder with digital metal gear hitec servo. rx not included.
3. motor cage installed with epoxy to gurantee strength.
4. landing gear mount no cracks at all and also reinforced with epoxy. no sign of stress on carbon fibre landing gear too.
5. Thrust 30 motor.
Controller: Spektrum DX6i
Fix Wing: 3DHS Edge 540 41", World Models Zero Fighter EP.
Rotary Wing: Align Trex450 Pro.
1. the first picture show that the wing is actually locked using a screw and a nut. it can be detached, however, its not as easy as using a thumb screw. u can still use a spanner, but more hard work la.
2. the second picture shows a part of the cowl that i've cut away because landed once too fast, and the cowl 'ate grass' and crack, so i trim away the cracked part.
3. wheel pants abit shaky due to landing in grass too many times with wheel pants on. on the whole condition i would say is at least 8 because never crash before. tracking straight. and a carbon fibre spinner from PA is installed. esc included is 60 amp from hobbywing pentium.
4. if require any more photos do let me know. due to it being first come first serve. do let me know when u can deal at serangoon garden macdonald.
