Remember to secure your heli well to the fuselage this time hor.
As for making 5 bladed head... actually u do not need to. U can just get those commercially available 5 bladed head instead. Century is one of them. Main shaft diameter (your 500) too small for the rotor head? No problem, just get a brass tubing or stainless steel tubing and slot it in your 500 size heli main shaft. That will make the heli main shaft become bigger diameter {hmm... don't think dirty here hor}
Definitely looks better than HeliArtist. The mounting point position for landing skids appeared to be more correctly position. The refueling point is visible also. The landing and navigation light holes in front of the helicopter nose are there as well. The tail boom is tapered to the end...which is more scale. Not like Align MD500E for TRex450.
This fuselage might be good to do AH-6X (AH-6X is an attack helicopter version of "Little Bird" that capable of flying as UAV as well)
2nd mod to lift up the top and tilt the tail boom down a bit. Do this as I am running counter clockwise and the rudder control rod is on the top, thus lowering the boom.
