WTS: GEPRC Hummingbird Racing Drone + 20 Gemfan props + 1 extra GEPRC motor
This topic is closed.
    $150
    Whatsapp 81848208
    Frsky XM PLUS Receiver(ONLY BNF) Version
    Specifications:
    Brand name: GEPRC
    Item Name: Hummingbird Racing Drone
    Frame: GEPRC GEP-HX2 (3mm bottom plate thickness version)
    -Wheelbase: 110mm
    -Thickness of bottom plate: 3mm
    -Thickness of side plate: 1.5mm
    Motor: GEPRC GEP-GR1106 6000kv
    Propeller: GEMFAN 2040 3blade
    GEPRC STABLE F4 Tower (GEP-F4-BS12A-VTX58200-M)
    -Flight Controller: Betaflight F4 OMNIBUS
    -ESCs: 12A BLHeli_S/Dshot150/300/600 16.6(G_H_30/L_H_0)
    -VTX: GEP-VTX58200 48CH Mini FPV Transmitter
    Camera: RunCam Micro Swift 1/3" 600TVL FPV camera 2.1mm lens CCD (PAL Format)
    Receiver: Frsky XM Plus (ONLY BNF INCLUDE)
    Weight: 85g (without battery)
    Flight weight: 120g (include 4s 450mAh battery)
    Feature:
    -The GEPRC flying team carefully calibrations PID, the factory to the binding receiver can fly.
    -Using the mature GEP-HX2 frame, and the base plate to 3mm thickness, all 3K carbon fiber main board, strong resistance to fall.
    -Using the GR1106 6000kv motor and Gemfan 2040 3 blade propeller and 3s 450mAh battery, perfect match, efficient and violent.
    -Using STABLE F4 Tower, easy install, stable
    -Using Runcam micro swift camera, make sure clarity
    -Tested the best speed 120km/h+
    BNF:
    1x Hummingbird FPV Racing Drone
    2x Gemfan 2040-3 Propeller
    2x Battery Strap
    1x XT300-M
    1x Battery skid resistance
    1x Frsky XM PLUS Receiver(ONLY BNF)
    Sold
