Pyro 750 Motor Bearing Replacement
    Here is how I open the Pyro motor to replace bearing.
    The same can be used to replace the motor shaft.
    1. First thing you need to remove the circlip (c-clip) with a spring clip plier.
    2. Then you need to remove a few shims (there may be 3 to 5 pieces), follow by a spring spacer.
    3. Next, to pull the motor can (rotor) away from the stator (the winding block).
    To make thing easier, I slide in two screwdrivers into the stator (be careful not to damage the motor winding)
    and place the motor near the table edge (see picture below).
    I then hold the two screwdrivers with one hand and hold and pull the motor can away with the other hand.
    4. Once you pull the stator and rotor apart , you can then remove the bearings on the stator.
    You can knock out the bearings using a screwdriver from the inside.
    For the bottom bearing, you need to remove the two screws nearby.
    Main Bearing: 6900ZZ
    ID = 10mm
    OD = 22mm
    Thickness = 6mm
    Bottom Bearing: 6800ZZ
    ID = 10mm
    OD = 19mm
    Thickness = 5mm
    5. To remove the motor shaft, you need to knock out the locking pin at the bottom of the rotor.
