Remember to do ESC throttle calibration after the firmware upgrade.
How can you tell if the ESC throttle needs calibration?
When the calculated headspeed (from the SR value) is different from what you measure (or read from the Tx).
hello sir,
You will hear a musical tone then two beeps. After the two beeps, lower the throttle stick to full down. You will then hear a number of beeps (one for each battery cell you're using) and finally a single long beep indicating the endpoints have been set and the ESC is calibrated..
