DX8 sailplane
    DX8 sailplane
    Newbie here.
    Setting up a powered glider with 2 flaps and 2 ailerons.
    Using the sailplane mode on dx8.
    Notice that throttle channel is not responding to the stick movement.
    Need advice. Thkq
    Hello,
    Most likely when using sailplane mode The stick is used for flaps/spoilers,
    And the motor is operated by a switch or slider,
    This is because a motor is only used to get the glider to altitude. And precise controls of flaps/spoilers is more important
    I believe this is quite common with spektrum transmitters.
    Don't have one around at this moment to check.
      I see.
      Ok thkq
