Transmitter
    Transmitter
    Hi, I have read from forum, the best transmitter is FM surface type. This is true? Can we use AM or FM for air? Please advice. Thanks.
    Can why not.
    Before 2.4 Ghz we used AM and FM on almost everything.
    I'm Remotely Controlled ...
      If you are referring for sub only FM is recommended. 2.4 Ghz can't penetrate water.
        Thanks for the info. Any suggestion of buying sub accessory in singapore?
          you can try contacting them
          At least this hobby lets you know where the cash you have spent on
