Zenm Tech General Product News
    Kylin's high precision and quality RC tools are now available at Zenm Tech.
    Tool ends are manufactured using only the best Japanese SKH51 high speed steel. A special heat treating process is used to achieve a score of 58-60 (HRC hardness). Yielding a durable and long lasting tool that is difficult to break. Further, the cutting tools are treated with a professional titanium plating process to reduce wear and maintain a sharp edge.
    Zenmtech is a rc company base in Singapore. Our product range include rc helicopter, multicopter, spare parts, esc, bec, lipo battery, etc. We are Align, JR, Zolta distributor in Singapore.
    Zolta Batteries Distributor
    KBDD Tail Blades
    The following KBDD tail blades are now available at Zenm Tech.
    KBDD 40mm Neon Lime
    KBDD 40mm Pearl Blue
    KBDD 40mm Neon Orange
    KBDD 40mm Neon Yellow
    KBDD 61mm Neon Yellow
    KBDD 61mm Neon Green
    KBDD 61mm Neon Orange
    KBDD 72mm Neon Lime
    KBDD 72mm Pearl Blue
    KBDD 72mm Neon Orange
    KBDD 72mm Neon Yellow
    KBDD 84.5mm Neon Lime
    KBDD 84.5mm Pearl Blue
    KBDD 84.5mm Neon Orange
    KBDD 84.5mm Neon Yellow
    KBDD 96mm Neon Lime
    KBDD 96mm Pearl Blud
    KBDD 96mm Neon Orange
    KBDD 96mm Neon Yellow
    KBDD 104mm Neon Lime
    KBDD 104mm Pearl Blud
    KBDD 104mm Neon Orange
    KBDD 104mm Neon Yellow
    KBDD 112mm Neon Lime
    KBDD 112mm Pearl Blud
    KBDD 112mm Neon Orange
    KBDD 112mm Neon Yellow
      Soldering Irons for RC Applications
      Introducing various soldering irons for RC applications. These are available at Zenm Tech store.
      #1 The RC Soldering Iron (30W/130W)
      This is a dual power soldering iron. Normally it is 30W, by pressing the trigger button, the power will be switched to 130W within seconds. This is very useful for soldering all kind of connectors and wires. This is a must for RC soldering.
ID:	978814 Click image for larger version
      #2 Portable Soldering Iron (60W/90W)
      This is a portable soldering iron for field use. Can be powered by 2S or 3S Lipo battery. Deliver 60W with 2S and 90W with 3S battery.
ID:	978811 Click image for larger version
      #3 USB Soldering Iron (8W)
      This is a 8W small soldering iron powered by USB. It is meant for soldering small connectors/wires, such as those used in micro helis.
        Zeal Blads
        Zeal blades (tail and main) are now available at Zenm Tech. Spinbaldes on the way.
          Spinblades Blades
          The Spinblades heli Symmetrical 3D main blades are here.
              Why no red ones?
              Too many helis!
                We only have Red Tip 700mm for now. What size are you looking at?
                  Too many helis!
                    I think you are looking at the special edition ones. On the way.
                      Swee!
                      Too many helis!
                        The Special Edition Spinblades 700mm blades have arrived.
ID:	979975Click image for larger version
ID:	979977Click image for larger version
                          paging for ah liang...
                          Heli-ADDICTION:
                            Bling bling ..... I spend enough this month with towkay Tan. Need to rest and recuperate.
                            Too many helis!
                              Multi RX Signal Converter
                              We are glad to announce a new device.
                              The is a mutli Rx signal converter. It will be able to convert Rx signal from one standard to another.
                              FUTABA PWM → FUTABA S.BUS
                              FUTABA PWM → JR XBus
                              FUTABA S.BUS → JR XBus
                              JR PWM → JR XBus
                              JR PWM → FUTABA S.BUS
                              JR XBus → FUTABA S.BUS
                              PWM (traditional Rx output signal)
                              Multi Signal Converter XBUS-SBUS-PWM XBus to SBus Converter SBus to XBus Converter PWM to XBus Converter PWM to XBus Converter
