It all depends on the level of mismatch of the individual cells.Its designed to handle 350mah and under most circumstances it is more than enough.However, a gross mismatch and high capacity cells may cause problems.That's why if there is a vast diff. in voltage between cells , it activates a circuit which prevents charging.
They then recommend trickle charging to bring the battery back to balance.
