Good Tap and Die set
    Anyone knows where to find good tap and die set that can make screw thread for RC use?
    Thanks.
    basically all works the same, you can find at most of the hardware store
      Thanks Mike. I thought for RC use...the size is much smaller so may not be able to find easily.......
        what size you looking for?
          Maybe 2-3mm
          Are these common measurement?
            yeah, basically u still can get M2 & M2.5 tap The smallest I had is M2
            If u want "Good" tap, try asking for machine tap. The are identical to hand tap but are more "sharper & durable" U don need to "back out" when taping
            Mike
              Thanks Mike.
              I saw the Sherline mill at Winnie's place. Is your "machine" also the same size?
              That's small !!
                Slightly bigger .... higher power rating
                Mike
                  1mm & 1.5mm die and tap?
                  Any one try looking for these before?
                  Trying some mod on my HB.
                  VinCopter
                  Share the joy of flying . . .
                    VinCopter ,
                    not sure if they carry 1mm to 1.5mm, but can try,
                    Allinton Engineering & Trading Pte Ltd
                    803 King George's Ave
                    #01-234, S(200803)
                    62960679
                    Allinton is a one-stop online hardware store in Singapore. Our hardware shop offers a huge stocklist of hardware tools for all. FREE islandwide delivery.
                    give them a call before going down, they don't keep stock, need to call first.
                    Very near to Rotor.
                    XRB SR Lama
                    Robotis Bioloid
                    Robot Bear
