So far, I've made aboout at least 6 flights and I absolutely love it. With the power loading of about 178 watts/pound, it's overkill. But with relatively good throttle resolution with modern ESC and 3S lipo, the spectrum of flight speed is fantastic.
During the maiden flight, a deliberate push of throttle sent the ship skywards and after a couple of down trim clicks and 1 click on the aileron trim, the rest of the time is filled with loops, square loops, axial/barrel/snap rolls, cuban eights, inverted flight and whatever I can remember from the book. While not exactly good at precision aerobatics, it does show it's capability and maneuverbilities.
The glide ratio is a little too good that landings approaches needs to be done from far and low or overshooting is eminent. But with this light weight and low inertia, you can get away by diving it with throttle cut and level off just a few feet above the ground and stretching the glide while bleeding off the excess airspeed, before touchdown. By the way, this mdel can really slow it down to a crawl before the model drop its nose, with the ailerons still effective.
