The Cool Tool - Unimat 1 !!!
    Originally posted by HZM View Post
    Oh... from what I see, if you get the Metal Line version, you will be able to fabricate your own CNC mount using the machine itself cos it had mill and lathe function within its configuration.
    Can the classic be use as well?
      Yes too but i deem it will be more work cos the travel range for classic is smaller compare to ML version. Thats is fr my observation.
      The Cool Tool Metal Line version will be offered at S$ 1699.00
      Introductory offer: S$ 1499.00
      small cnc machine, dremel rotary tool, proxxon tools, mini metal lathe, desktop cnc machines, small cnc mill, sherline cnc machines, dremel Singapore
        Looks good. Any idea if its easy to convert to CNC?
        I've my 3 nema23 motors, motor drive etc which hopefully can be use here.
        Need too change the leadscrew like a sherline conversion?
          IMO Nema23 is way too big. A suitable size will be Nema17 .. the physical dimension fit the cross section of the unimat.
          I am currently seeing details of Unimat 1, will not be too difficult to get it to CNC,
          I had do some test cutting. If you need a little tool/machine to perform lathe / mill, this is the machine for you.
          Mike <br> <br>
            these are the pictures of your cutting? Or it is from other places?
              aiyo don suan lah I just test test nia.
              Anyway this tool is cater for those not into very deep machining. Perhaps making some coupler + plate + drill sort.
                no no, serious question.
                The feedrate of the above cutting is perfect man ... Can lathe the slop manually some more...
                so its not you?
                  Bro,
                  Can the classic mill out a hole with dia of 25mm of, say, 12mm aluminium plate?
                  If can, I'll just need this piece of cool tool to help me with my build than to buy assortment of tools.
                    so its not you?
                    Me lah.
                    Wongster. The cool tool cannot meet yr requirement.
                      looks good... what is the smallest hole it can bore.
                      What is the largest diameter the lathe it can clamp
                        I'm disappointed...
                          The standard collet that comes with the unimat is able to clamp diameter 1mm. For 1mm shank, if you choose to drill, you can go as small as 0.1mm diameter.
                          If choose to bore, we deal with boring tool as small as 0.5mm
                          The largest diameter the chuck can hold is 56mm
                            We had received a few enquiries directed from The Cool Tool after this posting
                            We are pleased to inform the Unimat 1 and Unimat Metal Line is now available at SG TOOLING
                              Hi Mike,
                              Any place/shop to view the machine?
                                We just brought in the stuff and currently still in process of finalising the arrangement w dealer on the selling arrangement.
                                You can visit www.thecooltool.com / http://shop.sgtooling.com for more details.
                                If you really keen, contact me and we made arrangement to meet up.
