Got 2 3s 1500mah lipo packs. Charged and discharged for 2 cycles fully. Cells were discharged from 4.2V to 3V each. Total charge and discharged capacities are constant and values are very close (1290mah - charge vs 1285mah discharge). Discharge rate was tested at 1C and 2C (both discharge capacities are similar) But isn't the lipo rated at 1500mah? Why is the battery over rated by more than 200mah?
Will there be such a problem with more expensive lipos? I mean are expensive lipos over rated as well in terms of capacities?
