I got the "Turnigy Accucel-6 50W 5A Balancer/Charger".
hi turnigy acccel cell -6
Originally posted by protyne View PostI got the "Turnigy Accucel-6 50W 5A Balancer/Charger".
Cause I also looking at the Mega Power Poseidon 860DS AC/DC Charger. Its exact same as Hyperion 0606i that I'm using now. About S$160 after shipping.
I'm spoilt with all the choices
Originally posted by HotDogBun View PostThanks. Now roaming around HC to see other stuff, long time never buy from them liao. Will note list down tmr then order.
I'm spoilt with all the choicesPractice makes permanent. Perfect practice makes perfect.
Originally posted by protyne View PostYes plenty of choices in life as long as there's enough dough
Anyway I'm quite firm on Ehawk1500
Not too fast, comes with TT BL motor also. $160+ before discount.
Actually want to buy MPX easy glider but heard NTC out of stock right?
Originally posted by HotDogBun View PostDough is enough I not limit my charger to $150. Extra charger so I limit better.
Will check mpx stock for u tml when I drop by FHPractice makes permanent. Perfect practice makes perfect.
Originally posted by protyne View PostGood on the eHawk! I can fly too! Mode2 bros!
Originally posted by HotDogBun View PostMight save the hassle of ordering. Pls let me know later when you going down. Made last offer for a charger, if deal don't go through need your help buy charger from JHPractice makes permanent. Perfect practice makes perfect.
Originally posted by BigKid View Posthey guys, my Acc-6 charger keep showing connection break!!! it was serving me well for the past 3 mths till today, do you guys noe what went wrong?
Originally posted by Lplate View PostIs it possible, the power supply not good?
Maybe thats why some people spend a bomb on good stable and huge power supplies?
Or possible just the balancing adaptor part is worn/old?
I stay in Pasir Ris and I work in Raffles area. Can collect from me at these two location. We can test it at the same time, that is if you want to.
hi guys, problem sloved! keep showing connection break! check all wires and soldering seems ok, decided to cut away the heat shrink tube for the deans plug and there is where the wire break! can't really tell cause the heat shrink holds very tight to the deans plug. btw after a few months of usage the charger not so accurate anymore even charging new battery shows 4.18- 4.17.- 4.18. can this charger be calibrate like the imax b6 ?thanks for all the reply cheers!
