my little toy boat
    Looking at the bottom of ur hull, u did not add any strakes. If you wana make it go faster, add some strakes. It helps to guide the water to the rear of the boat rather than to the side of the boat.
    Here is the meaning of skrate : http://en.wikipedia.org/wiki/Strake
    If u not too sure, look at the underside of various mono hulls. Real boats has them also.
    Nice work thou.
      Using my boat as an example : http://www.daddyhobby.com/forum/atta...1&d=1209256649
        Dis is wat i call boat building.D materials u have used to make d rudder n all, is great. Looks like the painting was done by brush. I can see u've put in alot of hard work on d fittings. One need a lot of patience n skill do dat. Great work man. I envy u, seeing u've done well wit d cutting. I've been trying to cut 5" rails for my hydro and till 2day have not been able to get it right. Have messed up 5 rails n still trying.
          Nice work thou.
          thanks for your advise and now then I know what is all that for
          c how much I know about boat ..... even I can build
          hehe upgrade program
            thanks man, building a boat is totally diff from a plane ...... a new experience and fun for builder
              Hi loyn.
              Can u let me know where u got d Foam from? Looking for floatation to put in my boats.
              Tks bro.
                Hi loyn.
                Tks bro.
                for normal white low density foam u can easily get from bookstore
                for higher density with or even blue foam u can get from artfriend or other art material store.
                  what power system are you using?
                  make it simple, make it strong, make it work!
                    refer to reply 14
                      No problem. I'm still learning too.
                        thanks for the advise I have added the strakes to the bottom of the little toy boat. It sure give it more "character" ......
                        faster or not is not that important after all, but to keep the water going onto the deck
                        hope for good weekend weather to give it a try again
                          When are u going??? I bring my little boat along too.
                            looks great!
                              Reminds me of my first few boat building attempts during sec sch
                              But i was only using cardboard and definitely nowhere as nice
                                bro dont like tat leh
                                your "little" is not that little .....
