hi johndyl.
currently charging 2x3s TPv2 2200mah battery with imaxB6 using 6s ports and Y connector, taking up to 3 to 4 hrs to balance charge.
even balance charging 3s alone takes just as long.
hi adrianli,
how fast does the TP-1010C takes to balance charge on yr batt ?
I'm using Mega Power Poseidon-860DS to charge my 3S batteries which I use for my MT. Takes about 45mins to 1 hour to balance charge back 1400mAh using 1.9A to 2A. Using multimeter to measure, the difference is always within 0.01v to 0.02v between cell, and the cell voltage is at 4.19v (for new batteries) after charge.
So far have no complain except I wish the alarm sound can be louder and also have configurable alarm sound level.
hi johndyl.
hi adrianli,
the one that adrian mentioned is a separate 10s charger and balancer system
the trick abt balance charging 2x3s is u gotta measure the cell voltages before u charge. if the voltages vary by alot, then the charger will not pump in alot of current.. it'll be trying to balance them first. even when used as a single 6s pack, the end cell voltages maybe different
the hyperion i am using balance charges pretty decently. definitely faster than what u mentioned.
For sale
Exactly. i think this one quite cheap. similar to IMAX B6 if not wrong with exhaust fan too.
yeah. gt a inbuilt fan. i using it, price is really cheap and similar to imax b6. but tink dun have the usb function and the temp probe seem to be quite troublesome to make it usable too.
Helis: Heli 1: Trex 450SE V1 Status: Fit Date of Operation: 27 JULY 08 Specs: JGF 450TH + RCE-BL25G + GY401 + HS-65HB cyclics + HS81 tail Radio: Optic 6 + Electron6 Batt: Zippy-H 3s 2200mah 20C
yeah same here! i just wish the beep will be loud haha eh how you deal wiith the dishcarging and charging heat ? or just leave it? haha just wanna share. i just leave it !
I use external power supply, not the in-built one. 3S charging is very cool. 6S charging is a little warm from the 2nd batt onwards, 1st batt is cool.
