lipo charger recommendation
    Originally posted by blueimage View Post
    hi i got Turnigy Accucel-6 50W 5A Balancer, but cannot charge, it show CONNECTION BREAK when i start charging... anyone can advice me???
    might be the charging charger. check whether any conenction loose. such as the dean side or banana plug side.
    Helis:
    Heli 1: Trex 450SE V1
    Status: Fit
    Date of Operation: 27 JULY 08
    Specs: JGF 450TH + RCE-BL25G + GY401 + HS-65HB cyclics + HS81 tail
    Radio: Optic 6 + Electron6
    Batt: Zippy-H 3s 2200mah 20C
      Thanks... but i have checked and all ok, could it be the adaptor problem??? i am using 3Amp 12V adaptor....
        Could it be refering to your batt?
          did u plug in the charging/dean cable?
          For sale
            just discovered something about some batts
            I just bought a hyperion EOS 0606i-b and tried to charge my batts. The indicated batt capacity is 1850mah so I set the charge rate at 1850. I get the message that said wrong batt input voltage. Fiddling about and getting very frustrated I tried lowering the charge capacity to 1700, it worked. Now my question is should I always set a lower charge rate or the indicated batt capacity is bogus? What will happen if I continue to charge my batts in this way?
            Having fun yet?
            36.39mhz
            40.77mhz
              alot of lipo charger in the market, for convenience you may want to get those with inbuilt balancers =o), my recommendation would be multiplex multi charger ln-6015equ
              link as follows:
              personally im a tp charger user =o)
                hi,
                suspect yr 12v power adapter might be under rated,
                experience this before with my previous charger warning read:
                "input voltage err"
                borrow a bigger rated ps n give it a shot or plug to yr car batt
                and check again the input voltage setting in yr charger is within range.
                  agreed, it is a power supply problem
                  For sale
                    The Charger is rated for 5A. ... u use 3Amp... ....... ???
                      3A 12V power supply is still enough. 3A x 12V = 36W. so as long as his charging current x batt full voltage dun go above 36W, it can be used.
                      Helis:
                      Status: Fit
