Needles imbalance
Trex600N landed
Originally posted by ammo View PostNeedles imbalance
When I drag full throttle, can hear the exhaust bubbling. SYmptom of being too rich at high end right?
But I'm at 2½ slightly more and it seems to be quite lean already? Anyway I'm on 20% nitro.
So which to adjust? High speed valve or low end needle? Richen or lean out?
Its hard to tell without seening how it flies.. but i'd re-adjust both needles
Originally posted by HotDogBun View PostThats the problem. I got a feeling its needles imbalance, but just not sure which to adjust.
So which to adjust? High speed valve or low end needle? Richen or lean out?Heli:
Plane:
. Ok Model Medallion
. E*Star Storch
. ElectriFly S.E.5a
. Mpx EzGlider (Slope)
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 430EX & 580EX2
. Canon 24-70 f2.8L
. Canon 85mm f1.8
. Tamron 10-22 ultrawide
I lean it out abit just now. No more chance to lean it as had to stop flying. Now it should be around 2½ turns. Previously I was actually on 2.75 turns, I stated wrongly. The transition sounds slightly better and there definitely was a big increase in headspeed. After 7 mins of flight, the bottom plate was not hot. Immediately after landing I can place my finger there for more than 10sec without feeling much heat.
Will lean out abit more and see how it goes.
The high end needle already leaned to what I wanted. I started working on the low end needle but had only 1 flight so cannot determine if problem is solved.
My lowest throttle was at 9.5% but Edmond's was at 6%. So I lean out the low end needle about ¼ turn slightly more. My take off on ATG Active mode was smooth, very smooth, without the RPM lowering during 50% to 75% stick.
Will confirm next weekend when I get to fly it.
Tail splitting
Found a crack on the tail fork, not too sure if ive over tightened something or just too much stress.. either way .. ive already upgraded to metal version.
Heli:
Plane:
. E*Star Storch
. ElectriFly S.E.5a
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 24-70 f2.8L
. Canon 85mm f1.8
Trex600 EP canopy
Ordered new canopies for my Trex600 electric from century-rc.
I thought the Align one looks really good, no idea why LHS didnt bring them in.
Heli:
Plane:
. E*Star Storch
. ElectriFly S.E.5a
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 24-70 f2.8L
. Canon 85mm f1.8
Hey, please keep us updated.
btw, i could be wrong about the throttle sticky issue, I was able to fix my 'overspeeding' issue by re-tuning my engine, it was due to the un-balance needles that Ken kept mentioning
I 'felt' the throttle and found it rough only a minute after cutting throttle, so maybe it would be obvious only if it gets too hot? and ive been running it on the richer side.
Originally posted by HotDogBun View PostThe high end needle already leaned to what I wanted. I started working on the low end needle but had only 1 flight so cannot determine if problem is solved.
Will confirm next weekend when I get to fly it.Heli:
Plane:
. E*Star Storch
. ElectriFly S.E.5a
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 24-70 f2.8L
. Canon 85mm f1.8
Will keep you updated. Or if possible join us this Sat or Sun?
Anyway my flight time is about 6min to 6½min ♠ only and left the header tank. How much flight time you getting out of each tank???
Originally posted by HotDogBun View PostWill keep you updated. Or if possible join us this Sat or Sun?
Anyway my flight time is about 6min to 6½min ♠ only and left the header tank. How much flight time you getting out of each tank???Stop looking for a gyro in my plane, they are all in the head.
im getting 7min+
Anyway my flight time is about 6min to 6½min ♠ only and left the header tank. How much flight time you getting out of each tank???Heli:
Plane:
. E*Star Storch
. ElectriFly S.E.5a
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 24-70 f2.8L
. Canon 85mm f1.8
Possible too .. since we're able to run richer for the same power on 30%
Originally posted by HotDogBun View PostVery strange indeed. Is it cause I'm on 20% nitro?Heli:
Plane:
. E*Star Storch
. ElectriFly S.E.5a
Tx: JR 9XII
Photo toy
. Canon 7D & 500D
. Canon 24-70 f2.8L
. Canon 85mm f1.8
Originally posted by CKS View PostPossible too .. since we're able to run richer for the same power on 30%Stop looking for a gyro in my plane, they are all in the head.
