3S 2200 mah Lipo Cost
    is that Ex lipo u mentioned being used in heli application?
    Also i always have a assumption when a same lipo (regardless of brand n cost) used in flying a heli 3D n used in normal flying in plane, the heli will actually reduces the number of the flight cycles faster compared to the flying of plane.
    Is this true?
    plane application but i over discharge 1 time, after that lose power already
      I see, so it is due to overdischarging.
      But my assumption not yet proven right ot wrong
        http://www.rcgroups.com/forums/showthread.php?t=905257
        Some HUGE plane application using fusion.
          Fusion is a good battery....i have use it for 1 year++...nothing wrong...
          After 50 cycles and 4 crashes the battery still okay...
          u can check the price in my web...
          cheers...
            which is better?
            Zippy-R 3s1p 2000mah 21C or
            Zippy-H 3s1p 2200mah 20C
            zippy-r seem to be of better quality but zippy-h gt 200mah more capacity. so which should i keep to fly my trex 450se?
            Helis:
            Heli 1: Trex 450SE V1
            Status: Fit
            Date of Operation: 27 JULY 08
            Specs: JGF 450TH + RCE-BL25G + GY401 + HS-65HB cyclics + HS81 tail
            Radio: Optic 6 + Electron6
            Batt: Zippy-H 3s 2200mah 20C
              Originally posted by luckysoul View Post
              which is better?
              If i were u, i will go for the better quality rather than more capacity.
              Quality is wat I look for in a lipo
              Unless zippy-H is proven to be better than zipper-R, then u got best of both world!!!
