Originally posted by teinsports
View Post
3S 2200 mah Lipo Cost
Originally posted by johndyl View Posti believe they r called jst-xh, the most common type for batts in asia
PRC Home - FPV Racing Drones, Fat Shark, Tiny Whoop - iCharger, iSDT, & FMA Battery Chargers - Mean Well & Iota Power Supplies - ProgressiveRC
Cheers.
Originally posted by Murdanny View PostHi guys,
Thanks guys. Just got my Fusion packs yesterday. Solid looking packs! Have not maiden it yet but i will this evening somewhere around west area because will be at MI.
Im kinda new to electric so anyone has tips how to take care of your packs for the long run?
thanks!
Originally posted by jansonfinn View Posthey bro, keep us update on this batt ya? i.e performance & flight cycle
Battery pack was cool as air con.
Looking forward to its long run.Kedi AH !
Originally posted by Murdanny View PostHad my first flight with the fusion pack. Its power is really remarkable and headspeed was constant. I marked a 3 mins extreme 3D and pushed the Beam to its limits at BBAFC this evening.
zippy 3s 2200
i bought my zippy 2200 3s 20C at $19.99 USD, got 4 of them in the hc flash sale. so far so good. use it on my Acromaster drawing 30A, 336 watts. i feel that one of the most durable lipo is 3E. i had 3E 2200 15C for abt a yr and over 100cycles and still going balance and strong!!!
ps: wher can i get 3E lipo locally??-Ehawk 2000 Pro
-Mouton 1600 EV
-AMD micro chili
-HK Kinetic800
-SF Learjet45
Originally posted by Touch n Go View Posti bought my zippy 2200 3s 20C at $19.99 USD, got 4 of them in the hc flash sale. so far so good. use it on my Acromaster drawing 30A, 336 watts. i feel that one of the most durable lipo is 3E. i had 3E 2200 15C for abt a yr and over 100cycles and still going balance and strong!!!
For a really budget person (like me).... ah..too bad i'm still schooling.
Ok anyway.., this is what i got from overseas.... eh, ABF lipo 3s 2200mah. for $19.90 USD. Been torturing this battery..., like smashing into building in my school TWICE!.. and hard landings.
Now having my 10th cycle so far,no problem with power and duration...
My results so far is:
3900kv turningy 30-35A on my F-16 (4min flight time)
1600kv towerpro 20A on my flying wing (10mins flight time)
Er...no idea wad kv this is but AXI gold 30A on a balsa 1.5m trainer(7-8mins flight time)
1000kv towerpro 16A on a extra300 foamy (~10mins flight time+)
They have this nice nice white rubber sealen that secures the wire tightly that is comming out from the lipo...for protective porpose i guess.
Eh..btw this is just my suggestion to get this kinds of lipo if wanna go cheap and good!
(oh btw, my balancer in the picture is also beri cheap $10USD more then the cost of my ABF lipo)
Umm... but i do rather feel cheated when i started the hobby with $110 lipos 3s 2000mah.... wa kao -_- ..could have got like 4 of this batteries overseas.
Build it
Fly it
Crash it
Fix it
There is difference between $100 lipo and $40 lipo, 1 very good way to check is to use a wattmeter and pull full throttle with both your expensive and cheap packs after 20 cycles, you may see that the better quality one still holds high WATT at full throttle than the cheaper one.
I tried it and i see the difference.
Originally posted by viper1990 View PostFor a really budget person (like me).... ah..too bad i'm still schooling.
10 cycles is abit early to form conclusionsOriginally posted by viper1990 View PostFor a really budget person (like me).... ah..too bad i'm still schooling.
Umm... but i do rather feel cheated when i started the hobby with $110 lipos 3s 2000mah.... wa kao -_- ..could have got like 4 of this batteries overseas.For sale
Originally posted by hoppie View PostThere is difference between $100 lipo and $40 lipo, 1 very good way to check is to use a wattmeter and pull full throttle with both your expensive and cheap packs after 20 cycles, you may see that the better quality one still holds high WATT at full throttle than the cheaper one.
the cheapo lipo is >40 cycles
the ex lipo is only 10 cyclesFor sale
Originally posted by hoppie View PostYeah, depend on which Ex Lipo you get, i had 1 which only last 10 cycles
Also i always have a assumption when a same lipo (regardless of brand n cost) used in flying a heli 3D n used in normal flying in plane, the heli will actually reduces the number of the flight cycles faster compared to the flying of plane.
Is this true?
