Imax B6
    Imax B6
    Hi guys, anyone of you is using the Imax B6 charger?
    Does it need an external balancer?
    How does it compare to the 601BC?
    Modded Esavage + 4S lipo + KB45 2300KV + HW150A
    Brushless Esky Lama with dual swash
    Esky Dauphin
    Walkera Lama 2
    Walkera 5G6
    Sparrowhawk XB + 2S lipo + 60A brushless esc + 6000kv motor.
    Brushless Mini LST + single servo mod
    Brushless Micro-T
    Yes, with built-in balancer.
      No need.
        I heard that the balancing and voltage reading is not accurate.
        Anyone using it?
        Esky Dauphin
        Walkera Lama 2
        Walkera 5G6
        Brushless Micro-T
          balancing is for align/dualsky type tabs. so far, balancing quite ok. using multimeter to check. value for $ charger.
          Hover: STILL many many
          FF: so-so; fig 8s, nose-in hover
          Crash (Major): 4
          Back to flying... let the goods times roll
            How much do the values it differ from the DMM?
            Esky Dauphin
            Walkera Lama 2
            Walkera 5G6
            Brushless Micro-T
              can this charger charge 2 x 2s or 2 x 3s together.....? and where can i get the AC to DC adaptor for this charger.....?
                I bought the Imax B6 and AC to DC all from Jethobby. Personally, I find this charger very user friendly and have all the protection to cover people like me. Example reverse polarity when wire is connected wrongly.
                Balancing is good as well as I can get the battery to balance to 4.19 or 4.2.
                It come with a nice box to protect the charger as well.
                  Thats good might be getting one for myself soon..but can it charge 2 x 2s together at same time or 3 x 3s?
                    imax b6
                    Hi guys, just got my imax b6, keep giving me this "INPUT VOL ERR"
                    am using 3s 1000mah 11.1v cell, alarm warning on all mode of lipo charging except discharging which is working, battery voltage before charging show 11.5v when measured with a volt meter, will anyone please advise.
                    thank you
                      thank you
                      It's "INPUT VOLTAGE ERROR". Check your adaptor voltage.
                      Chai
                      Lets' moveon.......
                        3x3 cannot!
                        2x2 and 2x3 maybe can with special adaptor... thats means u connect in series as a 4s or 6s. but u need a set of "series dean connectors" plus series tab connectors
                        For sale
                          Originally posted by johndyl
                          3x3 cannot!
                          eh...pai se..pai se..it 2 x 3s... typo error...I was told that the estation and the imax r the same just that diff brands....
                          But wonder if there is a funtion that i can off the buzzer for after it has been charge...
                            Imax B6
                            blog.quantifly.com has a review on the IMAX B6 and also shows how to charge 2 x 2s or 2 x 3s together.
                              Imax B6
                              My mistake, it's 3X2S and 2X3S
