Originally posted by simonwoo
IMAX B5 Question
Originally posted by simonwooWow really ah, so how much does it help to charge again at 0.1A?
Problem is my B5 already shows 4.19 for all and status is full, so it doesn't charge up anymore (I always charge at 1C). But put the batt through the lipo indicator, it's obviously still quite a bit more to go...
Bro, did you compare the readings on the B5 and the multimeter? My lipo indicator is showing vast differences - eg. B5 says 4.19 but lipo indicator only shows 4.07. I've checked with some other bros using other chargers and at least the lipo indicator shows 4.1x for their batts.
Does this mean that my B5 is always under-charging the batts by as much as 0.1v?
Originally posted by BigKiddon't help much actually, ard 0.01-0.02 measure using multi meter.
Originally posted by simonwooBro, did you compare the readings on the B5 and the multimeter? My lipo indicator is showing vast differences - eg. B5 says 4.19 but lipo indicator only shows 4.07. I've checked with some other bros using other chargers and at least the lipo indicator shows 4.1x for their batts.
btw are u charging through leads? if u are some connectors maybe loose
for mine.. direct to balancer port, i consistently get 4.15/4.17/4.16For sale
