ya lor. I wanted to slow charge my lipo and it keeps stop charging at 66mins. Did some search and found that it's the safety timer. I have since changed to xpower.
Yes, that's the one T15 Tahmazo.
Eerr... but how come the picture show it can charge more than 66min?
Not sure this restriction still apply to the new T15 AC/DC Tahmazo.
Originally posted by baby_zyklon
ok, before I malu myself, we are all talking about the same t15, the tahmazo t15 charger right?
Well for all who think t15 cannot charge lipo for beyond 15mins...
I'm using T15... the older one where u need external 12V power source.
So far it did not fail on me. It can charge more than 70minutes. Each time when the current reaches around 0.3A with full voltage, it will stop charging and it is indicate charge completed.
My experience is similar to SH. Mine stop charging when charge rate around 0.25A+/-.
TBH, unless they changed the charge rate program, otherwise, it would be pretty difficult to fully charge a lipo in 66mins using the charge rate in my t15. It applies even if you are drawing only 70% out of your pack. Why do I say so, because the amount of time that silly charger spend in <1/4C charge rate(i.e. <0.5A for 2000mah pack) is SUPER DUPER LONG.
Why don't both of you try to slow charge your lipo and see if T15 charge beyond 66mins. I recalled that if I charge at 0.7C it goes beyond 66mins...
Can try?
Thanks for the input
But I don't think it's the power cut-off issue as I'm also using the ATX PS.
The T15 always stop with normal finish beeping sound at the same timing (66min).
So can I say, your T15 can do charging more than 66min?
The link provided by baby_zyklon shows the picture of a T-15 where timer reads 74:42mins right?? BTW. What's the reading 00996 says?? and is 74:42 even a timer??
00996 should be the mah charged i think if it is like the imax and triton
For sale
