Originally posted by talcum
hi dood,
im no pro here either but if you read all the resources on LiPo batt maintenance you will find a few key things
1.) dont charge over 4.2v per cell
2.) dont over discharge below 3.0v per cell
3.) typically the voltage holding capability of the batt drops significantly after about 80% of the capacity of the batt is used.
4.) keep the batts cool to the max extent possible
and the list goes on and on.. so in summary ... these batts are quite sensitive. you dont look after them right dont expect to perform.
how i baby the 2.2A hxts.
1.) i check the batts with the MM once they arrive so see if its balanced right and in good storage voltage.
2.) i slow charge the batts 0.5A till a min of 4.15v per cell (+/- 0.02v)
3.) slow discharge the batt (UH website is max 10C) at or below 10C with wattmeter for about 1700mAh... approx 80%
4.) let the batt cool until room temp and use MM to check if the batt discharged balanced
5.) 0.5A charge to full cap.. about 4 hours give or take a bit. (btw im using the HXT chargers which seem to work well with the batts and only costs like USD$25 .. another no brainer .. btw its almost exactly the same as the Tahmazo chargers sold locally but like $20 cheaper)
6.) Repeat 1-6 for 3-4 cycles. if you are ground running the batt try to give it some cooling airflow.
7.) for normal flying i will charge at 1.0A. if i need it pronto i will charge at 1.5 or 2.0A however i will fly less aggressive and/or fly a shorter duration.
8.) i take note of the imbalances in the batts before and after flights and accord special attention to the problematic batts
9.) HXT batts will inevitably bloat. do not worry. if the cells are balanced then slow charging at 0.5A - 1.0A will decrease the bloat. many of us have experienced this.. and the batts work perfectly fine when pushed.
i have one current batt almost hitting 40 cycles and its starting to show signs of a dying cell. balanced charged will have all the cells to within 0.02v of each other .. typically about 4.13-4.17v however discharged one of the cells is about 0.15v lower then the others. i fly this batt as per norm like the other batts for the first 2 mins then i gradually change the type of flying to commensurate the capability of the batt. its still doing what i need it to do.
at approx $50 per 2.2A 3S .. if i can hit 50 cycles .. its good enough for me ill dispose the batt. thats about $1/flight. whats great is that for the same amount of capital i can have 2 flights within the same amount of time cause i have 2 cheaper (but well performing) batts as opposed to 1 expensive (yet highly reliable) batt.
so i could choose 4 TP/FP 2.2A 3S or i could choose 8 HXT 2.2A 3S .. and maybe have 2 with problems .. still have 6 functional batts.. while waiting for the 2 replacements... hhhrrrrrmmm 6 batts .. 2 extra flights per session. guess who will be improving faster
it is a pain to constantly check on the batts .. but hey thats why they are cheaper. oh btw.. i do NOT recommend using these batts above their 20C rating .. cause it seems that it cant really handle that portion well either. WOT on the ground on my plane is 42-48A.. should be within limits of 44A in the air. in any case the batt is supposedly capable of handling 32C burst.
hope it helps. ask the other PFW'ers how they are using their HXT batts to get additional feedback.
This is a comprehensive report, Talcum!
Question:
After the weekend flying session, I immediately charge my batt when I reach home. Thereafter, the batt are kept till the next weekend.
Should I continue to do this, or, should I leave the batt in the 80% discharged condition, and then charge them the day before I fly?
Thanks!
MS
