imax b5 charger
    imax b5 charger
    i have the imax b5 charger
    it has a lipo balancer option.... i can use that to balance my balance my batteries
    but... issit good enough or issit better to get a separate balancer?
    What goes up must come down ... its a matter of how
    try it lor bro, charge liao use voltmeter to check each cell..
    For sale
      So far I find it pretty ok. But the charging time can be quite long to peak the batt's capacity.
      The individual cell indicator reflected correctly after checking with a voltmeter.
      _____________________________________________
      "Success is the ability to go from failure to failure without losing your enthusiasm."
      "Great works are performed, not by strength, but by perseverance."
        Where to buy?
        $169.00 - Imax B5 Li-po balance charger
        Is there any where to get cheaper than this retail price?
        Thanks.
        "Keep Fly'in Till They're Dry."
        Mini Titan E325 SE Version
        Full CNC Metal Rotor and Tail
        Futaba GY401/Futaba 9257
        Hitec Optic 6 Electron/HS65HB
        Maiden on 26 Aug 2007
          bro how do u see the individual cell voltage?
          I've tried charging with Lipo (thru deans) and Lipo Bal. During charging / stop charging i press INC/DEC can't see individual cell volt. Only total volt.
          Practice makes permanent. Perfect practice makes perfect.
            Originally posted by Heliguy
            Thanks.
            try going hk ;)
            For sale
              Thanks.
              search for imax on ebay. But you won't have local warranty and support.
              cheers
                Jon,
                Before charging, select BAL CHARGE and not LIPO CHARGE during the setup process. Because the LIPO CHARGE mode do not show balancing status while the BAL CHARGE shows all the cells status while charging.
                BTW IMAX B5 sold by us comes in 12 month warranty against manufacturer defects and 1-to-1 exchange is possible if the manufacturer defects is beyond repair. Please keep your receipt to proof your purchase from us.
                We were informed user's abuse and damaged will be assessed by the factory to conclude repair cost.
                Regards
                SKY HOBBIES SINGAPORE
                Tel : +65 6293 3968
                Website:
                Official You Tube Channel
                FACEBOOK :
                  well if u wat green and cheap go indian order. but if u go local u can have after sale service
                  mike
                    Hi
                    like wat sky has mentioned, select the lipo balance charge feature to charge your lipo. During charging, just press the INC to switch between individual cell voltage monitoring or overall voltage and amp display.
                      Thanks guys. Got to see individual cell rating. It was not set to Lipo Bal as mentioned by Derrick.
                      This is a nice charger. Bro Heliguy just get it from our local hobby shop and be backed by warranty/service.
                        Sweeet!! Dood bring it down to the field so we can all check our batts on it
                        Powder, Anyone????
                          Okay. THanks for the info
                            You'll probably be charging it at home as well. Will need a ac adapter ya.
                              the only cons for this charger is only don hv discharging features,i would prefer 601BC instead of this..
                              T-Rex 450SE
                              Sanwa RD8000 TX
                              E-Sky Lama V3
