think the 200ma is called the balancing current working in the balancer circuit, rather than being called the discharging current. All balancers have this, even when they are not connected to any charger, doing static balancing.
discharging current is a charger circuit function whereby some load is applied to drain out the batt pack. only some higher end chargers have this. btw i dont think one should deep discharge a lipo, it hurts the batt..
low current discharge to 12V, can help reduce bloating sometimes
For sale
Just curious.
If after Balance Charge, using a multimeter, the results are 4.14V / 4.16V / 4.14V , is this good?
I've test with few lipos all seem to have this reading, very constant, but is it charging the lipo enough or the threshold to stop is set lower?
Mine not so low.
Abt 4.16 for old lipo
Abt 4.17-4.18 for newer lipo
_____________________________________________ "Success is the ability to go from failure to failure without losing your enthusiasm." "Great works are performed, not by strength, but by perseverance."
Just curious.
bro do u mean cell 1 is 4.14, second is 4.16 and 3rd is 4.14? then it isnt exactly balanced leh..
For sale
However most of the time, my lipos are max 0.01 difference between 1 cell to another. I do also get perfect balance cells sometimes.
Anyway to re-balance a pack when its within the 0.02v difference range?
I'm using a FP Balancer, DN Balance charger and Imax B5 and no way can I get it back to totally balance or at least to 0.01v diff.
I have 3 packs that i charge only via deans on B5 and it stayed balance or at most 0.01v diff. Different story for packs charged with the balance chargers.
Practice makes permanent. Perfect practice makes perfect.
How you guy connect your Lipo using Imax?After seeing the diagram,I was a bit confuse..It shown the lipo was connect with the balance tab and both the output of the lipo batt was connect to the charger as well.
Hi Guys I bought the charger and I am happy with its performance too. It comes with many attachments for many kinds of batteries. It also has a balance polarity reverser adapter so you connect it directly to the balance socket.
Provides lots of information like charge rate, time, charge amount and individual cell voltage.
Cheers!
