Raptor 50 Titan landed!
    But they need to be "squeeze" between the 2 surfaces until a thin layer (microns) before they'll work
    If you use globs of it "putty" style you'll be dissapointed !
      CarbSmart update
      Went flying today in very humid environment with occasional light rain.
      1st flight was tested with the CarbSmart at 75% sensitivity and set temperature of 110 degreeC. The flight went very well with consistence sounding engine and very little bogging (tested with tictoc mostly).
      On 2nd flight, set temperature was reduced to 100 degreeC. The flight went just as well, however with a little more bogging. Maybe I should run my OS50 in 110 degreeC?
      After loading the heli for a good 3min, I landed it and set it on throttle hold and noticed that the CarbSmart was holding the needle at the far end “RICH” (around 1 3/4 turn) position of the engine.
      It went back to the far end “LEAN” position (around 0.8 turn) of the engine just 5 seconds after I put it on hold.
      Before CarbSmart, i was flying with 1 turn !! so ive been running it too lean!!
      I was still able to place my finger at the base of the engine for 4 seconds with 1 turn though.
      Since the CarbSmart was holding on to the far end “RICH” position after I load up the engine, will mechanically richen the needle by few clicks to give it more room to dynamically adjust the needle. I aim to get the CarbSmart to position at midpoint when i load it up.
      Also, I did not feel any performance hit with the added weight (CarbSmart + HS81) on my already heavy raptor. Infact, the gain outweights the extra grams!
      Heli:
      Plane:
      . Ok Model Medallion
      . E*Star Storch
      . ElectriFly S.E.5a
      . Mpx EzGlider (Slope)
      Tx: JR 9XII
      Photo toy
      . Canon 7D & 500D
      . Canon 430EX & 580EX2
      . Canon 24-70 f2.8L
      . Canon 85mm f1.8
      . Tamron 10-22 ultrawide
        probably because of your wiring just kidding
        Helis
        Logo 500 3D
          hi
          how do u power the Carbsmart?? through an extra channel in receiver?? Y plug directly from BEC?? as for settings does it need the TX or is everything adjustable onboard the Carbsmart??
          thinking cause i have DX7 which is 7 channel, if use governer then no more channels left liao.
          CHEERS!
          450 PRO - Phoenixtech Scorpion 2221-8, Castle Creations Phoenix 35, Hitec HS65HB cyclic, Futaba 9650 tail, (hanger)
          MA Furion 6 - Savox 5055 560KV, Castle Creations ICE 80HV, Turnigy 959MG cyclic, HK47110MG tail, Castle Creations BEC pro, BeastX
          MA Fury55 - OS55HZ + Outrage EVO55 pipe, HS5625MG cyclic, Spartan + HK47110MG, Align 2 in 1, Align Governor.
          Kasama - Savox 5065 550KV, Castle Creations Phoenix 85HV, HK47110MB tail, Hitec 7985MG cyclic, BeastX
            You DON'T require an extra channel for carbsmart.
            It's its own system.
            Carbsmart CPU + sensor + servo.
            Thanx!
            SLOPE SOARING NOT A CRIME
              Yep, lu wei yao answered that, just Y plug from existing channel if no more free channel, it requires only voltage input. Not programmble from TX.
              Originally posted by stickman
              hi
              CHEERS!
              Heli:
              Plane:
              . E*Star Storch
              . ElectriFly S.E.5a
              Tx: JR 9XII
              Photo toy
              . Canon 7D & 500D
              . Canon 24-70 f2.8L
              . Canon 85mm f1.8
                hey Bro, read the latest Helicopter magazine and there was a review of Carbsmart. The reviewer similarly like you achieved the best result with 110 degree setting with no bogging and consistent engine running.
                This is temptin me man kekeke.
                  Ive been tempted, and i'm sold.
                  Now where to get the $$?
                  Thanx!
                    Thanx!
                    theres your anser
                    Helis
                    Logo 500 3D
                      My collections
                      It has been a good year of heli flying .. hopefully a 90 next year?
                      Thanks for reading/contributing to this thread and Merry Christmas to all
                      Heli:
                      Plane:
                      . E*Star Storch
                      . ElectriFly S.E.5a
                      Tx: JR 9XII
                      Photo toy
                      . Canon 7D & 500D
                      . Canon 24-70 f2.8L
                      . Canon 85mm f1.8
                        U got a new canopy for ur Trex600.
                        U need a transport for that 90 size. Consider it carefully. The transport can also help u hook up some babes along the way.
                          Yes.. thinking of both.. but need more vit M
                          anyone wanna hire IT security specialist/researcher?
                          Heli:
                          Plane:
                          . E*Star Storch
                          . ElectriFly S.E.5a
                          Tx: JR 9XII
                          Photo toy
                          . Canon 7D & 500D
                          . Canon 24-70 f2.8L
                          . Canon 85mm f1.8
                            Can anyone share pic of your circuit for the NiCd to the RX? I need some references to explore this field
                              Check ur Tx manual.
                              I attached a diagram from Futaba manual.
                                Thanks for the diagram.
                                A question, for the 2 wires coming out of switch harness to NiCd and Charging lead, they are soldered parallel right?
