The Bug Micro HLG
    Originally posted by HeLiCrAz
    Joe....I also want leh.Flyers....as u noticed,Joe built only 6 pcs.So I suggest pls submit ur name
    1. HeLiCrAz
    2.
    3.
    4.
    5.
    6.
    In case you haven't noticed, you're not the first in line... You're probably like the 6th or 7th....
    F5D Stratair Demon
    F5D Jibe
    Jiri Bachinski Escape Pylon
    Voodoo S400
    Kyosho Phantom 70 Reno racer
    La Racer 56
      Hi guys, hold your horse
      Shall we allow Joe more room to complete this report on the Bug Micro HLG first ?
      Regards
        Wah! Siao liao! What have I done???!!!!
          This is hilarious.
          Joe, looks like you will need alot of tea breaks.
          Thanx!
          SLOPE SOARING NOT A CRIME
            By the way, the first 2 models are for Johnnie and myself. Only 4 models to let go later. Gimme a break, I'd just came back from work after night shift.
              Originally posted by plug&fly
              Any chance of me getting one. This will be my first foray into unpowered gliding or soaring. Please, please please. Been away from the computer for the past week and missed out on the nano falcon orders. Well let me know.
              Don't worry, Chekgu. I ordered 2 Nano Falcons. I can let go one of them to you if you wish.
                Hehe, just kidding.
                In the end you're just doing these at your own time and leisure. Thats what it is all about.
                Thanx!
                  U had just became "Singapore Idol" in the forum everyone wants you now
                  Keep us posted how it fly
                    All I can say is.....
                    thanks for sharing all the information
                    is really an interesting and simple project to work on...
                    good for coming holiday period....
                    me go buy material liao....
                    btw plan to mod to motor drive.....no confidence to launch like that
                    later plane go up with one wing only
                      Joe,
                      U r the man!!!
                      Those of u who r able to get Joe's hand made craft should appreciate the hardwork he put into it. His workmanship is top notch.
                      Lucky, I'm not into gliders or planes if not I'll want one also.
                        Free plans can be downloaded here on this website.
                        Click on this : http://www.planet.nl/%7Espijk382/BUG.zip
                        Thanks for the link.
                        Adnan
                          Hi Joe,
                          could you pls post more pic of the part when you join the 2 CF spars? Also, what is the LE material/dimension?
                          Maybe with enough details, more of us could build our own Bug Thanks for sharing!
                            Originally posted by gEcky
                            Hi Joe,
                            Good questions. The plans never mention what is the material for the LE, but the article in the RCM says the materials used on the wings are only balsa and CF. So, I assumed that it is 1/8" balsa dowels. As in most construction articles I ever came across, all materials are considered balsa unless specified.
                            Anyway, I've searched high and low for the 1/8" dowel to no avail. I ended up using 1/8" square balsa sticks,and carve thier corners and sand the entire length to round. Works for me.
                            As for the CF spar joining, they are never really joined together. After building the 2 wings, they are simply butt joint together at the root ribs with epoxy. A strip of lightweight fibreglasscloth will be installed at the bottom of the joint and wrap around the LE to about 1/2" back of the upper wing joint.
                              Good move! But you may need to enlarge the fuselage pod a little. Anyway, micro plane experts like you shouldn't have much problem with that. Get building man, it's addictive. I got my 3/16" and 1/8" CF ube from Jet Hobby. I think Moh has only 1 last 3/16" CF rod.
                                Dlg???
                                wei yao, are u going to put a launch peg on the tip??? if so can i tag along n see u discus it?? i saving up for XP5 digital setup... so cannot afford to pay joe... see u launch i happy liao
                                For building is 1/2 the fun of this hobby
