DIY - Lipo Voltage Monitor (In Flight)
    Read a post recently on a DIY to build a simple Lipo Voltage Monitor and would like to share it with fellow members.
    The original document was prepared by Mr Gary Sweet and attached is the PDF file.
    Will post my little Lipo monitor in the next post.
    Heli
    Honey Bee CP2 : Sold (Maiden:17 Dec 05)
    Trex 450XL (CDE) : MM450TH, Quark 33A, GY401, JR RS10DS (Maiden : Align Frame - 1 Jul 06; SuperFrame - 29 Aug 06)
    Plane
    Estarter : Align 450s, Align 25A, Electron 6 (Maiden :16 Sep 06)
    PT-17w : Sold
    Buggy
    Acme NB 16 : Half 8 Nitro (Maiden :23 Dec 06)
    Transmtter : JR PCM 9X II, Aggressor SRX
    Charger : Tahmazo T15
    Balancer : TP205
    Battery :Thunder Power, FullRiver, Warbird
    I could not find the MAX 8211 voltage detector. However, I managed to find ICL 8211 which is compatible. All parts are available at Sim Lim Tower (Basement 1)
    1) ICL 8211 - Voltage Detector $3.50/-
    2) 510 Kohms $0.20
    3) 2.6 Mohms $0.20
    4) LED (bright) $0.30
    Some wires...thats all......Picture tells more..
    Heli
    Plane
    PT-17w : Sold
    Buggy
    Balancer : TP205
      More pictures
      Tested with several 9V batteries with different voltage and it seems to work fine. As I do not have a variable voltage power supply, it was difficuilt to determine the exact voltage that the LED lights up. Trial and error show that the LED will light up as soon as the voltage drops below about 9.4 ~9.5V.
      Current drawn is very low:
      when LED off, the current drawn is 0.02mA
      when LED lighted, the current drawn is about 5mA
      Looks good for now,....will put it on a test flight later.
      Heli
      Plane
      PT-17w : Sold
      Buggy
      Balancer : TP205
        DIY- Lipo Voltage Detector
        With a rather long wire (25cm) which I will eventually trim shorter, the total weight is 4 gram.
        Heli
        Plane
        PT-17w : Sold
        Buggy
        Balancer : TP205
          Voltage monitor
          thinks w kby e-flyler save $$$$$$,
            Hi helichoo,
            Thanks for the encouragement.....Makes the sharing more meaningful when you know that your posting interest some members..
            Heli
            Plane
            PT-17w : Sold
            Buggy
            Balancer : TP205
              Nice sharing...even though I think I do not need at the moment.
              BTW, is it same or similar to the one that someone posted before... quite sometime back?
              SH
                Newbie gadget
                Hi SH,
                Didn't realise it was posted by someone else before in DH. I actually learn it from another forum which was posted by Gary Sweet and was surprise to find a substitute IC available locally.
                For season pilot like yourself, I am sure you don't need such gadget which adds weight. Its for newbies (like me) who constaintly holds the fear that the heli will just suddenly drop from the sky.
                I also realised that controlling the time of flight should still be the first line of defence and intend to use this gadget as a "In case I lost track of time" situation. Anyway it is cheap (only $4.20) and the real reason is..."build for fun loh".
                Its a newbie's gadget for low flight. Once the heli goes too high, it would be impossible to see the LED...he he he....
                Post by newbie for newbie.
                All expert comment are welcomed, many many thanks for your encouragement SH.....
                SH
                Heli
                Plane
                PT-17w : Sold
                Buggy
                Balancer : TP205
                  hi w_kby, thanks for sharing..your posts always interest me..just like the one on mounting the gy401..
                  great to have guys with great creativity like you. i have a variable voltage psu for charging my batteries. if you do happen to be around bt panjang, do swing by so that you can test it out..
                    Thanks!
                    Thanks awesome for your compliment. I am still very new to this hobby and technically obsessed by the little heli. There are just so much to learn and plenty of knowledge from past forum threads. This hobby actually consumed my entire leisure time.
                    I will soon try the Lipo Voltage Monitor on the heli until it light up, then measure the voltage directly, so thanks for your offer, I think I do not need the variable PS for now.
                    However, I would like to pop by someday to met you up. Only thing is Bt Panjang is one place I hardly go and the last time I was there, I got lost.
                    Will certainly meet you up for a chat one of these days. Thanks for your "always helpful" gesture.
                    Heli
                    Plane
                    PT-17w : Sold
                    Buggy
                    Balancer : TP205
                      yes, these flying thing really catches your heart isn't it? me too, i hardly have time these days though always eager to fly..and when you're in it, every minute of your time is precious..
                      re this thing, i had thought about it previously ie. either light or sound indications but really, when your heli is far you'll probably not going to see or hear the warning..best is still to know your batt well (you should, after a few cycle) and using the timer on your tx. Its good that you spare some thoughts on this, though.
                      yeah, me too. would like to meet you one day and hopefully fly together..i have made some really good friends here in this forum, since started this hobby about slightly over a year ago..
                      and you are not the only one who will get lost there..hee - i get lost wherever i go hee..
                      no problem about helping lah, if i can and provided not too inconvenient for me..
                        Variable voltage regulator
                        w_kby,
                        u sound like you are familiar with electronic circuits. Why not make a variable voltage regulator using a LM317. Many designs can be found on the web on this IC and seriously, u don't need to be electronics trained to build one. Then u'll be able to test ur LVD (total cost <$5 for this little proj)
                          You are Awesome right about knowing thy battery!
                          I remember the last hover I flew until heli refuse to take off. The voltage then was about 9.5v. So, if I rely on the LED, the heli may have crashed. May need to change the LED triggle voltage higher.
                          Heli
                          Plane
                          PT-17w : Sold
                          Buggy
                          Balancer : TP205
                            Hi gEcky,
                            Thanks for your information.....Loves these $5/- gudgets....Will go find out later.
                            Originally posted by gEcky
                            w_kby,
                            Heli
                            Plane
                            PT-17w : Sold
                            Buggy
                            Balancer : TP205
                              U can use 2 or more resistor in series... and then the o/p is tap between that series of resistor to give u voltage divider.... therefore, can create a very very very simple variable voltage supply.
                              U can use potential/variable resistor to do the job as well.
                              SH
