Hi zattan22,
I am unable to open the PDF file (after the data migration) which shows the 1st version voltage monitor circuit. So can remember the detail. If you have a copy, please repost.
Based on the text for 1st version, you should us 510K ohm with 2.6M ohm resistors.
Wonder why you are using the 3.9M ohm resistor. Please also make sure you have the correct value by measuring with a ohm meter.
Please change the resistor to the correct impedance.
hOpE ThiS hELPs
hOpE ThiS hELPs
Originally posted by zattan22
